fulltimin
Nov 23, 2021Nomad
navegator wrote:
Remember that some glues brake down with long exposure to water or moisture, that is the difference between regular plywood and marine plywood.
If you are thinking of using it for the sink, "do not!" In the long run you will have a real mess, stick to tne epoxy and the fiberglass, that sink will be ausome and a work of aft.
navegator
Definitely not using that on the sink. I already have what I think will be enough Epoxy for that job. I do need to add a curve at the bottom of the sides of the sink, to make cleaning easier before adding the Epoxy.
38,705 PostsLatest Activity: Jan 14, 2025
