kmb1966's avatar
kmb1966
Apparently a new Onan generator is needed - no repair
My 2001 Itasca Suncruiser has an Onan Marquis Gold 7000 generator even though it is a 30 amp motorhome, not a 50 amp. Started giving a code 37, brought in to the Onan service center. Service center says debris in the engine, bent rocker arm, burnt valves, some damage to excessive HEAT. Despite all of my religious oil changes, exercising, filter changes and only 750 hours, the unit will cost over 1900 to repair. Can't see spending that much money on that old of a unit. Also, I never understood why the unit came with a Marquis Gold 7000, when a 5500 appears able to do the job. My unit has basement A/C where the 20 amp circuit is tied directly to the 1st compressor (pulls about 12 amps) and the 30 amp circuit is tied to the EMS 30 amp system for the 2nd compressor and the rest of the unit. The Onan 5500 would appear to be able to handle this setup fine, and the Onan 7000 produces more power, but I don't see how I could utilize that extra power with the way it is wired. New Onan 5500 is around $4,000 and a new Onan 7000 is another $1,000
I suppose I am going to go with a new Onan 5500 with new warranty. Onan service center says it can solve the heat problem with a modification to the bin door with a louver/vent and a heat shield. Still trying to get details before I pull the trigger on this deal. Opinions welcome. Thank you in advance.
