C20 wrote:
Doug,
I'm not an expert in how they operate, but all he did was jump a switch on the circuit board and it operates like the 400 series aqua hot with two pumps. That's the way i understand it. I'm sure trainer could answer your questions, he's been working on them for for 25 years. As i said I'm no expert but he is.
Sorry, he has worked on them for 25 years and he does a Mickey Mouse repair like what he did? Your 450D is NOT functioning like it should and if you paid him you got taken. He should have fixed it correctly OR he should have told you, I got you running, but you need to get it repaired correctly. I am assuming he did this.
Note: In order to get pump #2 to activate at the proper time
there is a jumper pin connecting pump #2 and Pump #3 on
the electronic controller. There is no Pump #3 on the Aqua
Hot 400 series.
YOU HAVE A PUMP 3 WHICH IS THE STIR PUMP. The 400 does not. So, it appears you NEED Pump 3 replaced which is the Stir Pump. He should have told you this. Doug
