CharlesinGA
Jul 26, 2016Explorer
Replace the boost relay, it sounds like the contacts are going bad. They eventually burn up and don't work at all.
There is no isolalator, other than the boost/charge relay. Mine had got to the point it was not passing any current at all.
If its a round silver contactor, the generally accepted replacement is the Cole-Hersee 24213, which will require a 14 or 16 gauge ground wire with a large ring terminal to fit the mounting screw, and a small ring terminal to fit the small terminal stud on the contactor.
Charles.
Charles.
38,705 PostsLatest Activity: Jan 14, 2025
