mlynds's avatar
mlynds
auto levellers not working
I have a 2011 coachmen Mirada 35 ds. the levellers are not working. there is no power to the panel. we checked all of the fuses excluding any in the engine compartment. any ideas what might be wrong?
  • Gjac's avatar
    Gjac
    What brand, model levelers? Mine is a HWH 200 series and I found my fuse in eng compartment. I think it was 15 amp in a holder marked ACC. It was caused by the 12v power into the controller that was grounded when it became trapped in the emergency brake mechanism.
  • It could also be the gear shift or e-brake switch. Mine has to be in "N" and the emgerancy brake on.
  • Executive wrote:
    1. Post model and brand of levelers you have.
    2. Check all fuses INCLUDING any in engine compartment, bedroom closets, under the bed etc.
    3. You may have to pull the panel to find a hidden in-line fuse beneath.
    Good luck...Dennis
    we pulled the panel off and didn't see and inline fuse. a friend of mine is a mechanic when he testes the red wire there was no power to it. I found the fuse last night for the leveler motor it was fine.ill check the fuses in the engine compartment.
  • 1. Post model and brand of levelers you have.
    Good luck...Dennis
  • In My Coach the Fuse is located near the HWH Motor in a separate in line fuse holder!
