Paleo's avatar
Paleo
Auto Park Brake Issue or Not?
Just purchased a 96' Winnebago Adventurer 32 on the Chevy chassis. During the test drive, when I tried to put the RV in reverse, the auto park brake would engage and you would have to wiggle the shifter to make it disengage. When u stop, and shift into reverse or any other gear, u can hear the pump whine, then the light goes off, so I figured it needs some maintenance, not a big deal.
Well, I drove it to the storage unit, and when I got to the storage unit (and even before then really), I could hear some brake squeel coming from the rear and maybe an ever-so-slight drag. When I hopped out, there was a small amount of smoke coming from the rear tire rims, so I assumed the brakes must be dragging some from not being used, again, nothing a little maintenance shouldn't take care of.
However, when I got home I started googling and reading horror stories about how these auto park brakes get chewed up and cost $4k to fix, I'm really freaked out now. From what I understand though, the smoke couldn't have been caused by the auto park brake b/c that's closer to the front of the rig correct? It seems there is some fluid or something that is sticking to the rear wheels, is this indicative of something other than just bad brakes? (PIC)
I was going to drive it to my mechanics but now am unsure if I should try to drive it for fear of causing major damage b/c of the APB, am I overthinking this if the light is off when I am in drive and the rig seems to roll fine? Should I have it towed instead and if I do, do I need to tell the tow operator to drop the driveshaft to prevent damage b/c of the APB?
Thanks for indulging in my paranoia :D
