- DavePExplorerI also have the BC20 camera and Garmin GPS. It works very nicely in my Rialta. I plan to add one to my class C. I mounted my camera inside the Rialta so the lens doesn't get dirty.
- BumpyroadExplorerjust noticed at Sam's this am that there is a $50 deal on that camera putting it at about $200.
bumpy - BumpyroadExplorergo to http://www.manhattan-products.com/usb and they may have a bunch of different ones.
garandguy wrote:
Bumpyroad wrote:
garandguy wrote:
Here is the link for the X500 at Sam's Club. Will the cable for the rear camera reach to the back of my 31 foot class C?
http://www.samsclub.com/sams/tw-x500d-bundle-dash-cam/prod18360227.ip?searchTerm=THINKWARE%20X500%20Dash%20Cam%20Bundle%20with%20Rear%20View%20Came
I think it came with a 22 ft cable. I bought a 6 ft extension for $14 off amazon.
bumpy
I looked on Amazon. Could not find. Do you have a link?
search for 6ft USB Micro-B Male/Female Extension Cable Manhattan 307420 and you should hit it. don't have a link.
bumpy - garandguyExplorer
bumpy
I looked on Amazon. Could not find. Do you have a link? - BumpyroadExplorera while back somebody posted a source for custom made wiring. I am sure that they could put together a micro a/B cable whatever length one wanted.
bumpy - garandguyExplorerHere is the link for the X500 at Sam's Club. Will the cable for the rear camera reach to the back of my 31 foot class C? Just found out that the cable for the rear camera is 21 feet long. Emailed ThinkWatch as to whether they make a longer one or if it can be made longer.
http://www.samsclub.com/sams/tw-x500d-bundle-dash-cam/prod18360227.ip?searchTerm=THINKWARE%20X500%20Dash%20Cam%20Bundle%20with%20Rear%20View%20Came - j-dExplorer III replaced the wide-angle the prev owner had with this 11 x 14 from Amazon. It's a huge help.
- DrewEExplorer IIOne other thought: Can you see a back window from the inside rear view mirror in your unit? If so, have you tried one of the stick-on fresnel lenses? Although probably not quite as good as a rear view camera, they are very helpful and very economical and not subject to interference or bad connections.
If you get one, buy the largest size that fits in the clear view of your window.
About Motorhome Group
38,705 PostsLatest Activity: Jan 24, 2025
