Chasses E-450 Ford Filled fuel tank but could get no recite at fuel pump...!!! attendant tells me had 3 inches of rain day before and pumps were so wet recite machine not working in pumps. Drive a...
Im ready to go just as is but I will have a spare fuel filter to use if i get another check engine code.
I am going to check pressure of fuel rail and see if it is in spec. which I am sure it is.
I was told it can be checked with a tire gage because there is a Schrader valve on fuel rail. I will have to look and make sure that is correct. I was told that is the were jet cleaner is injected. so i will look and see.
