Iwannago
Jan 08, 2019Explorer
Bad gas ?
Just purchased 2016 Allegro Bay V10 gas. RV has been sitting for a long time, very low mileage.
Check engine light on, took it to a Ford dealer and they said it was a misfire on two cylinders, blamed it on bad gas which they said is not covered under warranty. They want 1000.00 to drain the tank.
If I don't they said injectors and other problems will not be covered later.
Should I just treat and run the 100 gallons out and clear light ??
Or should I go along with them. They said they tested the gas by lighting some on fire and it did not all burn.
Thanks
Jim
Thanks
Jim
