Balancing Rear Tires?
Marv_Hoag
Getting 6 new Toyos. Last time the only tires I had balanced were the fronts. Is this what most do, or do you have all 6 balanced? Not balancing the rears saves $100.00.
2000 Monaco Windsor 40
2009 Honda Fit Sport
2012 Chevrolet Equinox
26 REPLIES 26
RCMAN46
olfarmer wrote:
I say balance all. I have beads in mine and they mostly work OK. My MH sits for long periods of time and I do seem to have a little vibration for several miles once out on the road, it seems to go away after awhile. I think I would rather have them spin balanced. I suppose after sitting for awhile the beads kind of clump together on the low side of the tire? I am not sure if that is correct but that is how it feels to me when driving it.
Actually after a tire sits for a period of time the tire is deformed and it takes several miles for the tire to heat up and go back to its original shape.
This will happen regardless how the tire was balanced. The nylon bias ply tires of the past were very bad about this.
olfarmer
Ed & Ruby & the 2 cats
2001 Winnebago Brave 30W
7.4 gas Work Horse Chassis
99 Jeep Grand Cherokee
down_home
Balanced all of them on Road Force Balancer. Rides great.
Some don't balance the rears thinking imbalance among four drive wheels will even out.
It doesn't.
DFord
I've got a set of Centramatics for the Ford F53 V10 chassis setting in my garage because I couldn't tell any difference with them after I put them on. In my book there a waste of money that never helped me - on two different motorhomes. I hope they helped others get a smooth ride but they didn't do me any good.
Don Ford
2004 Safari Trek 31SBD (F53/V10 20,500GVW)
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
BlueOx Aventa II Towbar - ReadyBrake Inertia Brake System
DrewE
Besides the beads (and of course traditional weights), there are also the Centramatic balancers. It's the same basic idea as beads, but a spearate gizmo rather than something stuck in the tires. They aren't exactly inexpensive, but do work and work nicely.
(Just make sure your tire guys understand that the hole in the Centramatic disk for dually wheels is there so you can reach the valve stem of the inner tire, and should be so aligned....)
Hikerdogs
On our last motorhome we bought new tires for the rear at about the 40,000 mile mark. They were supposed to be balanced using Equal Balance Beads. As time went on the ride got worse and worse. It was obvious the rear tires were out of balance.
It finally got to the point that we stopped at a tire dealer in Florida and aske to have the beads removed , and the tires rebalanced with external weights. When they dismantled the tires they found no balance beads had ever ben installed.
The tires now were starting to get flst spots. They rebalanced them with weights, with one tire needing over 12 ozs. The other 3 needed around 8 ozs. each. Even with the tires now balanced the flat spots made the ride terrible. We ended up replacing them with only 30,000 miles on them. We could have probably gotten double the mileage from them had they been balanced when new.
Hikerdogs
2013 Winnebago Adventurer
wa8yxm
They tossed bags of balance beads in all SIX on my coach. Rides nice.
William_B
DFord wrote:
If you put that **** in your tires, be sure to let anyone that works on that tire assembly know in the future before they do anything to it. It can make problems for them if you don't.
You'll need filters on your valve stems to keep it out or your tire gauge.
Not true in all cases. The filters in the stem comes from using powder. I have used Dynabeads in my last 3 sets of tires. They are sized bigger than the stems, they ride fine, nice and smooth, and other than sticking them in when the tire is mounted on the rim, nothing else is required.
Full timing since 2004
2007 Holiday Rambler Navigator 45' DD Series 60
2019 Dodge Ram 1500 Limited
Our Blog
time2roll
Those large tires seem to turn so slow I am surprised they even need balancing.
Maybe about 500 rpm is all they are turning at 60 mph.
DFord
Don Ford
scbwr
Mile High wrote:
The beads are often used by the mobile guys because they can't spin balance from their truck. If you have them mounted at a shop, insist on the spin balance.
While many share that opinion, there are many folks that have been happy with balance beads. Seems to me there are pros and cons to either system.
2012 Newmar Bay Star 3302
Blue Ox Avail
BrakeBuddy Advantage
2015 Malibu
"Get busy living, or get busy dying."
Andy Dufresne, The Shawshank Redemption
Mile_High
I was quoted spin on front and beads on the rear 6, but they did spin anyway on all 8 because it was done at the shop for no extra charge.
2013 Winnebago Itasca Meridian 42E
2013 Jeep Wrangler Unlimited Sahara Towed
scbwr
Magnum beads were installed with my Toyo tires.
Quite a bit of information on their web page.
Blue Ox Avail
2015 Malibu
3_dog_nights
What is this "Beads" you speak of??
Bob & Lynn
2 Chihuahua's, Ella, Gracie
was-2013 Open Range 424RLS,06' Chevy 3500, dually, Duramax/Allison
also was - 2015 Winnebago Adventurer 37F, towing 2003 Jeep Wrangler
now - 2021 NoBo 19.5, 2019 Honda Ridgeline RTL (Talk about downsizing!)
