peterman1's avatar
peterman1
base to steps is rusted and cracked
hello and thanks for reading my post. the steps to my class a had a lot of movement in them so when i looked under the rv i saw two cracks on either side of the steps along the base above the steps themselves. i took the steps off and like i said before two cracks. any idea who could repair this in live in the cypress and houston tx area. would some type of welding shop could do this? i have a 2008 fourwinds hurricane 34b. im the heaviest in the family at 200 lbs and i do not know it would develop cracks. thanks again for reading
pete
  • Just went through this on my 06 windsport. The step box is pretty thin metal so I didn't think I could get it welded. In the end I cut a hole in the compartment next to steps and reinforced from the outside. Luckily I caught my crack soon enough as it was only a few inches long.
  • We had the same thing happen to our 2001 Adventurer. Keep in mind the 200 lbs. is on a lever about 3' long when the stairs are extended, so there is a fair amount of stress on the 4 mounting bolts. Also keep in mind you're constantly carrying heavy loads when you pack for a trip, go grocery shopping and, return home and unpack. Another step killer is using one of those stair support posts and forgetting to fold it up before retracting the stairs.
    As I mentioned the stairs will come off easily they're held in place by only 4 bolts. On ours I removed the stairs, measured the size of the plate they are attached to and made another one from 7 gauge steel. I drilled the appropriate holes to allow the stair mounting bolts to protrude through. Before installing the reinforcing plate I welded up the cracks in the original plate. The whole project took a morning.
    If you need to take it to a shop remove the steps first and have all the measurements. It should take the shop a couple hours or less to weld up the cracks and install a reinforcement plate. Around here welding shop rates are currently about $50.00 per hour. The plate will cost between $25.00 and $40.00. So for less than $150.00 you should be able to get a mounting plate better than new
  • If they can easily do it without hindering the mechanism, have them reinforce it when they weld it (hard to say if that's possible without a picture).
  • IN that area there should be a welding shop that can come to you for a repair. Try to take some pictures and some measurements so that when you contact the shop you can tell the welder what to bring so he can take care of it in one trip.
