โJan-14-2017 11:15 AM
โJun-24-2024 04:31 PM
Years later I have the same issue with a 2000 Newmar Mtn Aire. What did you end up doing?
โSep-23-2017 05:17 AM
โSep-22-2017 01:23 PM
โJul-07-2017 04:59 AM
โJan-29-2017 02:43 PM
โJan-28-2017 02:20 PM
โJan-28-2017 09:11 AM
โJan-14-2017 06:21 PM
AikenRacer wrote:
The floor underneath my fresh water tank was rotten. Just demo'd it. Pulled out the water tank. Plan is to clean up the metal support structure, put in a new floor and install the water tank back. The replacement floor will be about 4x8' with a cut out for the dump valves. Couple of concerns..
1) What do I use for the flooring? Need protection from road hazards on bottom and it needs to be strong enough to support a 6' x 4' vinyl water tank (there are 2 metal cross braces). Thinking about a sheet of marine plywood.
2) There was no drain anywhere on the old floor. Should there be one and if so, what kind?
Any comments welcome.
Thanks!
โJan-14-2017 03:33 PM
โJan-14-2017 03:29 PM
โJan-14-2017 02:43 PM
โJan-14-2017 12:55 PM
โJan-14-2017 11:49 AM
โJan-14-2017 11:39 AM
