A)What do you have running? Its the chassis battery, the only thing on that I know of is the light for the chassis disconnect.
B)When was the last time you checked the water? I checked the water after taking it out, water is full.
C)Do this for a real check. Leave all the lights on, then when the batteries are dead.
Check the water in both, top off to the marker with distilled new water. Then remove the cables on one, recharge it at 2 amps.
(this may take 24 hours)per battery
I need to replace the chassis disconnect relay since I don't believe it is disconnecting. I'm doing the battery checks since it is dropping off after a week or so. I believe that even if the relay wasn't disconnecting it would draw the battery down as fast as it is. I'm suspecting the battery.
