time2roll
Jul 22, 2020Nomad
Are you plugged in during storage?
The disconnect is probably just the house battery. Yes it is best to move the switch to off or storage when not in use and not plugged in.
Chassis battery to start the main engine remains connected and will run down same as any car. Although RV tend to have additional accessories that will run it down a bit faster.
If you are plugged in a great solution is the Trik-L-Start brand combiner that will connect the float charge from the house battery to the chassis battery and keep everything in good shape.
38,705 PostsLatest Activity: Jan 14, 2025
