โJul-22-2020 12:05 PM
โJul-25-2020 08:21 AM
DesertHiker wrote:To check this remove the negative cable from your battery, set your multimeter to 10 amps and measure the amp reading between the negative cable and negative post. A reading of greater than 1 amp is too much parasitic draw and will drain your battery. Mine will read about .4 amps and will take weeks to draw down to 80% SOC. ECM as Bud stated and some other things will contribute to this draw. If the MH will not be used for several months just disconnect the neg cable and the parasitic draw is eliminated. You should never have to recharge your chassis battery for two weeks of camping but if you do when you run your genset to charge your house batteries put your key in the on position and your chassis battery will charge at the same time your house batteries are being charged. Once you measure what your parasitic draw is post it here and you will get help to find what is drawing your battery down.Krusty wrote:
I would try to figure out what is drawing the battery down and fix that. ie: If you have a dome lamp switch on the dash that controls a dome lamp that has its own remote switch, make sure the dash switch is not left in the on position.
How can I do this?
โJul-24-2020 10:52 PM
โJul-24-2020 02:58 PM
Bud
USAF Retired
Pace Arrow
โJul-24-2020 01:54 PM
โJul-24-2020 04:54 AM
enblethen wrote:
The chassis battery is drained by the computer (ECM). There is nothing that can be done to stop this besides disconnecting the battery or installing small charger to it.
โJul-24-2020 02:24 AM
RambleOnNW wrote:I am right there with you. That is my experience and solution with our 2007 Phoenix Cruiser on a 2007 Ford E350 chassis.
On our moho the chassis battery also powers the electric steps. There is enough of a drain that I disconnect the chassis battery when not in use and regularly put a battery charger on it to top it up before doing the disconnect.
I discovered this by leaving the battery connected and with the various small loads plus the electric steps the chassis battery was drained in 30 days.
โJul-23-2020 08:54 PM
โJul-23-2020 05:17 PM
โJul-23-2020 03:04 PM
Bud
USAF Retired
Pace Arrow
โJul-23-2020 02:30 PM
bobndot wrote:
I just learned something , I just asked someone re your problem.
Ask your mechanic to put a clamp volt meter onto the battery feed wire to the alternator .
A bad diode rectifier inside the alternator could be allowing battery voltage to drain back into the alternator when the vehicle is off .
The diode should be acting like a one-way valve to allow voltage to charge the battery but if its gone bad, then it allows a two way flow. That could be your problem and its something to eliminate if it is.
โJul-23-2020 01:54 PM
โJul-23-2020 01:39 PM
โJul-23-2020 12:11 PM
