frankiebIII's avatar
frankiebIII
Battery issues
I purchased a new to me 2005 Monaco Diplomat in March. So far things have been great and I have been able to handle most small issues. It's survived a solid 1k round trip that lasted 2 weeks all while towing my 2013 Ford explorer.
I am very diligent about going through my checklist before I store the rig however it appears that this last time I did not disconnect the batteries. It has been sitting for about a 5 weeks in a storage facility about 30min from my home. I finally got time to get out to it yesterday and discovered the batteries were not disconnected. The chassis batteries were fine and it started right up. However, the house batteries were down to 8.3 and things seem to not be turning on. I have no where to plug it in for now so tried to problem solve.
1. I could not get the Fridge to start
2. could not get the generator to start even when using the Aux Batt button. It only has 61 hr and has worked flawlessly since I've owned it
3. I drove the Motorhome for about a half hour and saw no change in battery voltage.
I will have time to bring it home and plug into shore power this week and am hoping that the batteries will charge and all problems will be solved.
I wondering if I should be worried about not seeing the batteries charged a little after driving for 30min or not? Did I do any damage to the batteries by letting them drop so much? How much do I fill with water?
Thanks.
  • In my rig when you start the engine it automatically connects chassis and coach batteries so you don't need to mess around with auxiliary start switch. Anytime your coach batteries are low you should start the engine before you try and start the generator.
  • Normally the engine alternator should start to charge the house batteries once the engine batteries have been topped up so it is possible that the engine battery was down a bit so the split charge system didn't connect (depending on the sophistication of your system)
    To get the generator to start, I suggest you start the main engine and run it at fast idle for a few minutes and then hold the emergency start switch on for at least 10 minutes before trying to start the generator.
    Trouble is this may not work depending on which battery is used to pull in the emergency connect solenoid. If it is the house battery - which is likely - there may not be enough volts to operate the contactor. In that case you might need to bridge from engine to house batteries using jumper leads.
    Or you can plug it in at home - where if the engine alternator hasn't had enough time to get the house battery volts up to around 10, your on-board charger might refuse to switch to charge because it figures there is something wrong.
    If that happens then you might have to find a regular simple single rate charger and hook that up for several hours to bring the voltage up high enough for the on-board charger to stop sulking and do its job.
    Have fun
    Oh yes - if the water level has dropped below the top of the plates exposing them to the air, some damage may have been done - but to get them going again, add distilled water ONLY ENOUGH TO JUST COVER THE PLATES by 1/8". The fully charge the batteries by whatever means works and then top up with water to the BOTTOM of the split ring (which is usually easily visible when you look in - might need a mirror and flashlight. Eye protection is worthwhile just in case)
    If the water level is low and the plates are covered, then wait until the batteries are fully charged before topping up.
  • The aux button is to start the truck engine when the starter batteries are down, not to start the generator.That button draws off the house batteries. Your batteries are too low to start your generator most likely.Check to see they're full & Charge.
  • You fill the batteries up close to the top, where your looking down at the batteries you can see the water and it has a eye shape to the water. As you probably know use only distilled water! Next time you buy batteries for your coach get a good set of deep cycle batteries. Take your batteries when you get a chance in for a hydrometer check. If they read around 500 or more they should be good to go. Good Luck
  • If you have deep cycle batteries you should be able to recharge them. If you have a battery charger that would work or a adapter for your 50A to 20A plug for your home.
