Tom_Barb's avatar
Tom_Barb
Battery maintenance
Our little over night trip to spend the holidays with the G/Kids we found that our battery pack was dead (or nearly) in just 1 day, the coach stays plugged in to the 50 amp connection at the house, and the battery pack was fully charged when we left.
Over the past year I have changed all the house batteries, (4 new trojan deep cycle wet cell) the old ones were 6 years old and would not hold a charge over night. The inverter (Heart Freedom 458) has also been changed, and since then we have lost the ability to charge beyond 13.3 volts on the batteries. Yesterday I removed the batteries, cleaned the tray and batteries including all the terminals, on the pack, plus all the cable connections from the pack to the inverter. Then reset the inverter to recharge the batteries, 8 hours later we are back to 13.2 volts on the battery pack, but with a 2.2 volt difference between the 4 batteries.
So, I set the inverter charger to do a 8 hour equalizing charge. This takes the voltage up to 15.5 for 8 hours as per the inverter operation manual to disulfide all the battery cells. that charge was completed last night at 8:30, today the battery pack voltage was back to 13.2 float charge voltage. This is the float charge level maintained during normal charge.
Do you believe that I have cured my over night discharge problem.
There never was a high draw on the pack either while traveling or while parked other than the furness cycling, and the normal lights. That type of usage usually gets us 5 days on the battery pack alone.
