- J-RoosterExplorer
harold1946 wrote:
Thanks, Harold
One bad cell, sulfated battery/batteries, or stratified battery/batteries will not accept a full charge. and even a three stage charger will continue to apply current in an attempt to do so. The result is boiling and gassing off of electrolyte.
Get a good hydrometer and check each cell, it may just need a conditioning charge. - harold1946ExplorerOne bad cell, sulfated battery/batteries, or stratified battery/batteries will not accept a full charge. and even a three stage charger will continue to apply current in an attempt to do so. The result is boiling and gassing off of electrolyte.
Get a good hydrometer and check each cell, it may just need a conditioning charge. The most common malady of a battery is sulfating. - Older batteries do use more water. Otherwise check the voltage and relate that to temperature.
- Bikeboy57ExplorerI can think of another scenario. If one of the batteries in the bank has a bad cell, the charger never reaches the float condition and will boil them dry
- Sam_SpadeExplorer
korbe wrote:
They would lose a lot of water and I was refilling all the time.
That probably means that your converter never was dropping to a proper float level.
It might be poorly designed or it might have failed.
I think you should observe the charging voltages over a period of time to see if it needs attention. I think it probably does. - korbeExplorer
Sam Spade wrote:
korbe wrote:
My batteries appeared to over charge while plugged into shore power even with my 3-stage charger
What exactly leads you to believe that ?
If that is true, something has failed and needs to be fixed.
They would lose a lot of water and I was refilling all the time. And when I read my converter manual and found out that I do have a 3-stage charger, then I figured it best to just disconnect the batteries once fully charged and now I add water about once a year. - 300 watts is not going to be an inverter/charger but just a stand alone inverter.
You must have a converter to supply 12v power and charge the battery. Probably mounted near or integral to the 120v/12v distribution panel. Get a model number off the panel or the converter might be mounted right behind. - J-RoosterExplorer
wolfe10 wrote:
Brett, I just got back from a trip out to the RV. I own a 2004 Winnebago Adventurer it was Winnebagos top of the line gas coach in 2004. My converter is a Dimensions Unlimited. The unit is mounted under the stove below a drawer very near the batteries. The remote inverter panel is up to the front of the coach above the dash and next to the TV set. There is a small panel that has a off/on switch and a green light which does not come on when I switch the inverter switch to on. There is also a breaker switch above the on/off switch. My inverter is Model is WIN 12/300, Input is: VDC is 12.6, ADC 30, VDC 12.6, ADC 40 and output RMS/VAC 120, Watts 300-400* *= inverter can deliver 400 Watts of constant power for 20 minutes and the 300 Watts in the inverter is continuous. This is all the info that I could muster up! Thanks, John
What make and model inverter/charger do you have?
Do you have a remote monitor panel? - J-RoosterExplorer
wolfe10 wrote:
Brett, I'll have to go out to my RV and check!
Do you have a remote monitor panel? - J-RoosterExplorerThanks Doug for taking time out to explain that to me!
About Motorhome Group
38,707 PostsLatest Activity: Feb 28, 2025
