Jim
Jul 26, 2016Explorer
Bedroom slide slow creep inward...
The small bedroom slide in my '02 Winnebago Journey has begun to slowly retract on it's own. But only the bottom section. This is a closet slide on the drivers side. I first noticed it a week ago when I had trouble opening the bottom drawer of my chest of drawers. I pulled the slide in a few inches, then extended it and all the seals were tight.
Then a check tonight, I find the bottom of the slide has moved in over 1 inch.
The switch is in a spot that's impossible to just accidentally bump. And, just the bottom is drifting in towards the RV, the top seems to stay put.
It's a HWH hydraulic jacks and slides (2 slides) system but I can't tell if the rear slide is hydraulic or electric, it's hard to see under there.
Any thoughts on where I should start with this?
