Pico2011 wrote:
these Winn Journeys have very nice modern woodwork in them..very nice. Thanks Rail! anything mechanical I should look for?
Pico2011, As in all coach's at any price or trim level, the #1 thing is water intrusion! Then the mechanical side, which can be checked by oil samples, and a good inspection!
The Journey's have a 1 piece fiberglass roof, which it very good! Also, it has the auto start feature for the generator, if you leave, and it gets too hot or cold inside or your battery's get low!
You have many choices, in your price range, it will come down to which one jumps out and grabs you! Then you will have to decide if it is the one with the best records, and care! I would be looking for a one owner, with all the maintenance records available!
The reason I said the Journey, was it had all the things you wanted, and had the big motor, which also got very good fuel mileage!
I also like Country Coach's, Foretravel's, Monaco's, Beaver's, Newmar's, Tiffin's, in that order. JMHO Rail!:C
