brandonrv
Jul 31, 2014Explorer
valhalla360 wrote:
Propane for the fridge should be fine but you will be pushing that 30amp outlet to run 2 AC units.
Keep in mind a 30amp outlet is actually only rated for around 25amps. You might want to check the voltage drop to make sure you aren't killing your AC units with low voltage.
What do you mean by check voltage drop? Just make sure the voltage is not dropping below some threshold?
38,707 PostsLatest Activity: Feb 18, 2025
