John_S_
Jul 31, 2014Explorer II
But what is the load drawing the AC voltage down too? I do not run two acs on a 30 even when I had a LP fridge. It will eventually trip the breaker. My AC units use 14 amps each and more at startup. Unless you have a EMS to guard against low power you need to look carefully at your laid there. There is a battery charger and converter running too.
