Speltier's avatar
Speltier
Bigfoot leveling system issue.
When I first got my 1990 Fleetwood bounder, the big foot leveling system worked just fine. On my recent trip, however, when I activated the system it goes through it’s diagnostic, but then all the lights (front left right rear) begin to blink. I left a message for their customer service, but haven’t heard anything back. Does anyone have any idea where I could begin to troubleshoot this? Thank you!
  • You know, I think I unplug both connectors on the back of the panel, perhaps that foiled the Reset protocol. Thanks for the tips, fellows.
  • From the Bigfoot website troubleshooting section:
    "If you have the "Front/Right" and "Rear/Left" lights flashing on your panel you must disconnect the interface cable at the panel or sensor for 10 seconds to clear the code. The interface cable has a 6-Pin connector at each end. It will be the smaller cable of the 2 that plug into the sensor and the only one plugging into the rear of the control panel."
    The level sensor is usually mounted on the inside of the firewall.
  • Check the limit switches at the jacks. Make sure you have good connections at the switches. You can unplug them and make sure they are "closed" using a continuity tester.
