โJun-04-2017 07:21 AM
โJun-27-2017 05:53 AM
PatrickA51 wrote:
I don't know if this is the right forum to ask this question.
I have a friend whose husband died a year or so ago. She has a Class C RV. like my RV. She doesn't know when the tanks were dumped last, I would say it must have been the last time the RV was used, but the RV has been sitting for several years. So my question is what is the best way that the Grey and Black Tanks to be cleaned out and what is the best way to sanitize the Fresh Water Tank is? I have heard that using RidX in the Black Tank might work, or just use Calgon Liquid water Softener in the Grey and Black tanks and drive the RV around for a coulee of miles and then dump it?
Thank You for any ideas.
If I posted this in the wrong forum would the moderator please move it for me?
โJun-27-2017 12:22 AM
โJun-20-2017 04:01 PM
โJun-20-2017 06:45 AM
โJun-19-2017 06:27 PM
4x4van wrote:
My bathroom sink is also plumbed into my black tank. Kitchen sink and shower go to my grey tank.
โJun-19-2017 11:19 AM
โJun-06-2017 02:40 AM
Dennis12 wrote:
Rockhillmanor,
I think that you are wrong about the wand that darsban posted. I was at a RV show that the Valterra company demonstrated their wand. They demonstrated the wand with four different types of angles going into the tanks and it worked perfectly. and this statement "And you will also be surprised how quick it takes to run the water in the sink to fill your black tank. Will make you think twice about washing up, brushing teeth in the bathroom sink if you have a large family. THAT is how black tanks fill up so fast" is also wrong. I'm sure if you look that you will see that your bathroom sink is trapped to stop what you are talking about. I know an inspector in the industry that would like to have the name of the manufacturer of the coach that puts any sink water into the black tank.
โJun-05-2017 09:10 AM
Photomike wrote:
I was told years ago to fill the black tank with some extra water when leaving the campground (if you dump at or near home) or the night before the last day (if you dump at the campground)and let it sit overnight. Then dump and you are good. So far it has worked fine and I don't use any additives.
One suggestion for a good cleaning was to buy a bag of ice, fill the black tank and dump the ice in as you are driving. The ice scrubs the tank with the movement and then melts so you can dump.
โJun-05-2017 08:56 AM
โJun-05-2017 08:38 AM
โJun-05-2017 07:49 AM
โJun-04-2017 04:41 PM
IAMICHABOD wrote:
But I got tired of dragging the hose in and all the mess that it made
It looks like this when finished, with a quick disconnect on the end.
Don't get discouraged if it leaks at the hose connections at first they are sometimes hard to get tight. Tightened mine up and have had no leaks anywhere.
Another suggestion is to make a test hole in a piece of wood or something and test fit the device to the hole. I found that the hole size suggested was much larger than needed.
Good Luck.
BTW Welcome to the Former Rental Club
โJun-04-2017 03:45 PM
โJun-04-2017 01:37 PM
