ItohamExplorerMay 16, 2015blowing FuseNeed some input to help out a friend who is having trouble with his class A blowing a "Bus" fuse on the side of the motor (gas) when he starts the generator. MH has been in storage through the winter,...Show More
MrWizardModeratorMay 16, 2015are you talking about a little glass control fuseon the front of the generator control box ?this will be internal to the control boardswhile wires running to the remote switch inside can get chewed onthese wires normally use a grounding circuit signal not a hot 12v signalto test, unplug the control wire plug going into the side of the control box, normally a straight line molex connector and use the start button on the genset to see if it will start without blowing the fuse
Related ContentFuse panel locateElectric tongue Jack blows fusesAwning Blowing FuseBlowing fusefurnace fuse blowing
