wa8yxm wrote:
Way more efficient by the way.. For any given trip it will suck less than half the fuel your Motor home's generator will.
Depends on the loading.
- Under light load, Inverter-Generators are more efficient as they can throttle back and use less fuel.
- Under heavy load, the losses converting DC to AC make them a little less efficient.
So if you are maxing out a small generator running the air/con on a hot day where the air/con never cycles, you will probably use slightly more fuel due the conversion losses.
On the other hand, if the air/con is only running 25% of the time, you will probably save fuel as 75% of the time the generator is throttled way back to idle speed.
