revflyr's avatar
revflyr
Brake controller plug in
I'm trying to find the plug for a brake controller for a 2015 Winnebago aspect 30J. This rig is on the ford E450 frame that came wired with a 7 pin plug at the receiver. I have looked left of the Steering wheel per Winnebago's manual and also removed the side kick panal with no luck. Did find a couple of inline fuses that are not marked behind the kick panel. Can anyone tell me where the plug might be? Thanks
  • Good luck with that. It took me three days to find mine and only after I finally got a smart person at Freightliner to guide me through the search.
    Those things are never in the same place with two different coaches.
    It's probably under the dash, but not necessarily so. It could be in the side kick panel too. Keep looking, if still can't find it, contact Winnabago/Ford to see if it actually was installed. Maybe it wasn't.
    Ron
  • Should be tied up under the dash OVER the gas, and brake pedal. Should be 2 plugs under there, one for OBD, and another for the Brake controller. You will prolly still have to install the relay to charge the trailer battery.
