Brake for toad
58roadhog
My Brake Buddy has died and I am looking for a good replacement. Any advice on a good system would be appreciated. I have a 2009 Allegro Bus and am towing a 2011 Chevy Silverado.
DW:Martha Real Boss: Joy (Australian Terrier)
18 REPLIES 18
mscamping
I would look at M&G or Air Force One for that vehicle.. These both use the vehicles power brakes and are not a dead pedal type of operation.. Mike Mathews..
2003 Holiday Rambler Neptune 36 PBD - ISB 300 Cummins- Allison MH2000 5 speed
2013 Equinox w/Blue Ox Aventa II & SMI Stay-n-Play Duo
FMCA 331658 HRRVC 105155 Chapter - 57- Good Sam Life Member - Coach Net - 3/4 timers
Mike & Sharon
dverstra
ThunderingQuiet wrote:
luvlabs wrote:
An SMI Airforce 1 would be the way I would go. You have air brakes on the bus and the AF-1 ties directly into that. Nothing to remove each time, just plug in your electrical and an airline.
X2 on that.
I've been using the AF-1 for about 3 years. It works great, dependable and no problems. The best thing about this is there IS NOTHING to adjust. Just hook up the quick disconnect air line and the cable going to the breakaway switch.
There is nothing to do inside the car, no big box that sits on the floor, just unlock the steering wheel and pull a fuse if your vehicle requires it. But then again if you do it with the system you have now that's a mute point. When you're done towing no box to remove and have to store somewhere.
SMI Air Force One
X3 on the SMI Airforce One. Simple...easy to hook up! You won't regret it
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...Holy Cow....what a ride!"
2007 Holiday Rambler Navigator
2013 Honda CRV
Returned Peace Corps Volunteer - Sierra Leone
pablo77
X10 - ReadyBrake. Simple and reliable.
Pablo77
'08 Mandalay Presidio #3469
wny_pat1
X-9 on the ReadyBrake.
โ€œAll journeys have secret destinations of which the traveler is unaware.โ€
Pixguy
X8 on the ReadyBrake
2007 5320LX NRV Dolphin on Ford Chassis
2010 CRV Toad w/ Readybrake system
Snomas
I went with the RVi brake system. It's non invasive and easy to take in and out. I had an SMI for 9 years.
2006 WINNEBAGO ASPECT 29H Ford E450 Super Duty
2018 F150 Lariat Crew Cab, Coyote 5.0 L RWD
67Cutlass
X2 on that.
SMI Air Force One
2012 Phaeton 40QBH
2015 Jeep Cherokee
SMI Air Force One
Retired USAF - CEVG and AFTAC
Member of Tiffin RV Network Forum
roam1
X7 on the ready brake !
willald
X6 on the ReadyBrake, for the reasons already mentioned.
You just can't beat it, IMO - costs a small fraction of what all the other systems cost, no electronics to fail, overbrake and damage your toad like electronic systems are known to do. Nothing to have to install and take out every time you tow. Just simple, no-nonsense cable-operated braking that just works, period. I won't own any other braking system.
Will and Cheryl
2021 Newmar Baystar 3014 on F53 (7.3 V8) Chassis ("Brook")
2018 Jeep Wrangler JK ("Wilbur")
luvlabs
2017 Winnebago Navion 24V
2014 Tiffin Phaeton 36GH (sold)
2012 Tiffin Allegro 32CA (traded)
2012 Honda Fit
rag-ftw
X5 on ReadyBrake. We pulled to Alaska and back last summer with one and once I got the tension cable adjusted it worked great on some very rough and steep roads! Cheap price, easy set-up, easy hook-up, and lasts a long time. What's not to like!
2004 Travel Supreme 38DS04
2009 Ranger 4X4 Towed
Ready Brake, Tire Minder
bluwtr49
X4 on Ready Brake. They're just too good not to at least consider.
Dick
2002 43' DP Beaver Marquis Emerald Cat C-12 505 HP, 1600 Tq
2003 Jeep Grand Cherokee Overland ---toad
rk911
Unified Tow Brake from US Gear. we have that on both our toads and love it!
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
427435
x3 on the Ready Brake. No electronics to go bad along with possible ruined toad brakes.
Mark
2000 Itasca Suncruiser 35U on a Ford chassis, 80,000 miles
2003 Ford Explorer toad with Ready Brake supplemental brakes,
Ready Brute tow bar, and Demco base plate.
