cotten31ExplorerJun 05, 2014Brake Pad stuck after releasing Air BrakeI had one of my rear drum brakes stay engaged after I released the air parking brake. Just one shoe on one wheel. I was told to put it in gear and "give it some gas". Sure enough after a few tries it ...Show More
J-RoosterExplorerJun 06, 2014Have your brake assembly checked to see what is causing this! Could be a flat spot on the brake cam or a weak return spring. Good Luck
Related ContentAir Releasenew released invertor generaterStuck zippers.Slide Stuck, Awning StuckWater filter stuck
