dufferdj's avatar
dufferdj
Broken Trimark RV door lock (06-650)
I went out to our 2010 Jayco Melbourne and when I tried to unlock the door to the coach, I found that it would NOT unlock. I then entered the RV by way of the Ford E-450 entry door. I tried to open the coach door from the inside, only to find out that the deadbolt would unlock, BUT the latch assembly would not retract allowing the door to open.
After looking on this website I found that I am not the only one to have this problem. Had there been a need to evacuate the RV in a hurry due to any emergency, that locked door would have delayed our exit --- definitely a safety issue.
Now that I know what the problem is --- I need help fixing it. A part in the latch assembly is broken, preventing the door from opening. I ordered a replacement door lock and tried to remove the old, defective lock. Although there are only 3 screws holding the 2 parts of the lock "sandwich" together, when those screws are removed, the screen door and the door jamb prevent the removal of the inside panel.
I contacted the manufacturer of the Trimark lock and they e-mailed a diagram of the lock. It only shows which part is broken --- not how to remove the defective lock.
Can any of you that may have had this same problem explain/have access to u-tube info on how to remove the old lock? Even a photo of the inner works of the door lock might help.
Thanks in advance...
