wolfe10
Feb 16, 2016Explorer
Snowman9000,
If you are asking if there gasoline coaches with build quality comparable to a 2001 Foretravel U270, the answer is NO. But, it likely cost at least twice what the most expensive gas coach did when it was new. Not reasonable to expect quality to be the same.
BTW, no difference in build quality between the different Foretravel models-- just drivetrain and equipment differences. Same construction.
BTW, here are specs on the 2001 Foretravel U270:
http://www.beamalarm.com/foretravel-links/models/2001-u270-foretravel-specifications.pdf
38,709 PostsLatest Activity: Mar 09, 2025
