buying running light amber lens covers
Treefrog
These 4x2 inch rough KII ovals that adorn practically all MH periodically crack or break, even if I don't hit things.
Last replacement time I had to buy the whole mounting assembly with lights, wires, etc., which was pretty expensive for what I needed.
Does anybody have a line on where to purchase just the lenses?
2000 Country Coach Intrigue 36' 350 Cummins ISC
2015 Lincoln MKX
FMCA 351235
Look for us at Civil War Reenactments and the SCA.
10 REPLIES 10
Fleet_Man
As others have mentioned, check the numbers/codes molded into the lens cover. Some are unique or captive to specific applications and are not readily available at the usual auto/truck parts outlets. Check RV Parts: Winnebago Outdoors. They have a number of different clearance light lens covers listed. That is where I found what I needed after searching the usual sources.
2007 Winnebago Journey 34H
Toad, '08 Ford Taurus X
Blue OX, Aventa
US Gear UBS
Fishinghat
I've bought replacements at NAPA. They were the two wire kind that didn't depend on the chassis for a ground. It has been a number of years, but I remember the cost was very modest and nothing to loose sleep over. The LED's are a little more expensive.
Holiday Rambler Navigator DP, Hummer, and Honda VT1100C Shadow
dons2346
They can also be found in truck stops
DSDP_Don
Treefrog.....Unless CC used an odd lens, here are some on Amazon. You could go with a sealed LED or buy just the lens, about $6.00.
It sure sounds like you're going through lenses quickly. You might try spraying them with some clear paint (lacquer) to give the a little better weather protection.
Amazon
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
rgatijnet1
Those things are inexpensive. If you do a little searching, you can probably find sealed LED replacements for a couple of dollars more than just the lens. If you go for replacements, be sure to get the two wire type since most coaches do not use the body as the ground.
enblethen
Look closely at one of the lenses. get the model number and the SAE number, then post back with them.
There is many lenses that are close but they must be the correct ones or they will not fit.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Ivylog
4 x 2 implies a clearance light and plenty of both on Ebay.
Upgraded with a 08 HR Navigator 45’...
1492
Moderator
Moderator
Moved from Forum Technical Support
RoyB
There should be a number etched into the lens. This number will match up with an exact replacement lens at most Auto Parts and RV stores.
BARGMAN is a big seller of RV SAFETY LENs covers... Search on GOOGLE for many sources...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
donn0128
Most any RV parts store has the lenses. You can now buy LED replacement assemblies reasonable
