Rangerman375's avatar
Rangerman375
Camco shower hose
Can the chrome camco replacement shower hose be used in an rv with the nylon/plastic fittings?
Purchased one and can't seem to get it tight enough at the faucet. Don't want to force it and end up with a bigger job.
Thanks.
  • Thanks everyone. Seems as though the washers that came with the replace hose were too small (thin) for my particular application.
    When I used the original washers everything worked great.
    Really don't like to manhandle plastic plumbing so I hope you understand.
  • downtheroad wrote:
    Should work...make sure you also have the little, black (rubber) washer inserted.
    X2 on those washers.
  • Should work...make sure you also have the little, black (rubber) washer inserted.
