guaranteed's avatar
guaranteed
can not propane inside MH
Propane problem with just purchased used MH.
Unit is a 1987 Georgie Boy Encounter.
When purchased unit was hooked up to external propane tanks and all was working fine with Hot Water, stove, and furnace. External tank was hooked through its own regulator to house line without MH reg in use and house tank was empty. When I got unit home I stopped and had 10 gal of propane put in. Vent was open on tank but did not blow propane. I then hooked up original house regulator and slowly opened the tank valve. Gages inside show 1/2 full LG ob both dash gage
and gage on kitchen counter.No propane in unit and do not hear air or anything. I open the tank vent and get air and then I crack the nut from the tank output before the geg and just get continuous air.
I am not sure if I should shut tank valve and disconnect at reg then open valve till I get propane gas. Maybe I should take unit back in and have tank filled.
Very new to RV problems but want to be sure of what I do.Any help appreciated.
Bruce
