mattdenryter's avatar
mattdenryter
Car dolly question..
Hello all.
I just purchased a 2018 Pacifica. It can be towed on a dolly per the owners manuel. It does not have a locking steering column. Does this mean that I can not use a pivoting dolly? I thought I understood now I’m a bit confused.
Thanks
  • The "Club" would mare your door or seat/console over time (ask me how I know). I now use a 1" web strap with the cam clamp (not the ratcheting type). Routing the web from the seat base up to the steering wheel back down to the other seat base.
  • You can also wrap your shoulder strap/seat belt around the bottom of the wheel and insert it in the seat belt retainer.
  • When we had our dolly, we used a ratchet strap with 2 wraps around the bottom of the steering wheel and the ends hooked to the seat mounting brackets. Easy to hook up and worked well.
  • You will have to secure the wheel with a "Club" and some rope. It doesn't take much to hold a steering wheel stationary.
