djlind
Aug 17, 2013Explorer
Carefree Eclipse Awning will not operate
Motor replaced last fall. It has worked properly all season. While prepping for a departure in a couple days I see that neither the inside nor outside switch will activate the motor. I confirmed the power switch is on, and it shows the red light. I checked the fuse in the front electrical panel. It is a CB type (I'm not an electrical guy, I assume that means circuit breaker). My meter shows continuity across the pins of the fuse and 12.6 volts across the fuse socket. Is there another lockout, or another fuse somewhere I need to check?
Thanks!
Thanks!
