golfknut's avatar
golfknut
Carrier Air V A/C replacement
What are my option for replacing our 13 year old Carrier Air V air conditioner?
I know Carrier no longer makes RV air conditioners.
The unit is tied into controlling the furnace.
The remote control controls the furnace operation as well as the air conditioner.
Thus we do not currently have a wall mounted thermostat for the furnace.
  • golfknut wrote:
    So fishing the wiring through the ceiling and down the wall to the new thermostat location was not a big deal for them?
    And not an expensive project?
    Well - - it may have been somewhat of a "big deal". Camping World charged me 1.65 hours of labor ($212.85) to install and wire the thermostat (which itself cost $58.99).
  • j-d's avatar
    j-d
    We have a wall-mounted thermostat controlling furnace only, and I believe it has only two-wire control cable. I'm considering controlling the temperature of our non-ducted Coleman Mach (two knobs on the ceiling assembly) with a relay, and I'd need to run more wire and in the opposite direction than what's there. I believe I would run it surface mounted. This is one example of a conduit/molding to let you do that.
    I might be able to get wire into the wall and up toward the ceiling, but the ceiling itself is "structural foam" so there's no void to run wire in. I might find a passage with OEM 120-VAC power to the A/C, but I'd guess at least the wall-to-A/C unit thermostat wiring would have to be across the ceiling surface.
  • So fishing the wiring through the ceiling and down the wall to the new thermostat location was not a big deal for them?
  • golfknut wrote:
    sch911 & DouglasC,
    Did you have an existing wall thermostat before the AC unit was replaced?
    No. The Carrier had a remote battery operated control unit. Had to buy the new wall mounted thermostat for the new Dometic A/C. Camping World installed them both.
  • sch911 & DouglasC,
  • This fall I replaced my Carrier Air V with a Dometic unit. Camping World did the job (at the time most A/Cs were on sale). As indicated in the previous post, the Dometic has a wall thermostat which also controls the furnace.
  • One of ours was switched out for a Dometic unit. The Dometic wall electronic thermostat also controls the furnace and heat pump.
  • I did see that conversion kit mentioned in a post from many years ago but it uses the control box from the carrier unit. And I'm reluctant to use an electrical part from a 13 year old unit.
    It would be an easy fix though.
    I guess for the cost it could be used until the control box gave out.
  • If you were closer, I could make you a deal. I have a 15k Carrier 5 sitting in storage. Not interested in shipping. Sorry
    Dave
    • sprintmart's avatar
      sprintmart
      Do you still have your Carrier Mark V ? Where do you live ?
      • way2roll's avatar
        way2roll
        Navigator II
        You're responding to a post that 7 years old and Byron hasn't been on here in years.
