Snowwolfe's avatar
Snowwolfe
Carrying a motorcycle
Have a 370 pound dual sport motorcycle I would like to carry on the rear of the RV on something that slides in the trailer hitch.
Any suggestions?
  • I should have mentioned, but I did in fact upgrade my hitch. The stock unit was rated at 3,500/350, so I upgraded to a hitch and the dealer welded it into the frame extensions. It's now got a 10,000/1,000 pound hitch on it, not that it can handle it. But it does give peace of mind for my motorcycle.
  • Snowwolfe wrote:
    hershey wrote:
    Most MH hitches are not rated that high. Saying that, I wouldn't have a problem carrying a bike that size on mine. Make sure it has a couple extra frame connections to keep it from rocking back and forth. Something like MrWizards looks perfect.
    Most class A gassers are rated for 500 pound tongue weight.
    But the hitches aren't.
  • Most MH hitches are not rated that high. Saying that, I wouldn't have a problem carrying a bike that size on mine. Make sure it has a couple extra frame connections to keep it from rocking back and forth. Something like MrWizards looks perfect.
  • this rack tilts, sliding ramp is built in
    called tilt-a-rack
    this bike weights 300#, there are two versions, get the biggest one
  • We have used a Versahaul for bikes up to a KLR650. For loading single handed it needs a platform fabbed up that you can set the bike on the side stand once it is on the hauler, then tie down.
    It has a fitting to tension it in the receiver so it does not flop around.
    It has a Class 3 capacity receiver so you can tow with it. This is where I would mount the side stand platform.
    Loading with a helper is no trouble.
  • I bought a heavy duty steel motorcycle carrier that works off my RV's class 3 hitch on Ebay.(Under $100) I was concerned about the aluminum carriers not being strong enough for my 325# 400cc dual sport. It road 2400 miles from Dallas to Orlando with no problems. Saved me gas rather than pulling a trailer.
  • That's lightweight check out Discountramps.com....they carry a few different brands...
