wolfe10 wrote:
moisheh wrote:
NEVER replace that bearing with a sealed bearing. Contrary to some posts the C7 has a sealed bearing and a short life. Probably due to all the heat in that area. If that bearing lets go you will have a huge repair bill!
Moisheh
Let me expand a little, since Caterpillar has both sealed and greasable hubs available.
From BEST to WORST:
Greasable bearing that YOU DO GREASE.
Sealed bearing
Greasable bearing that YOU DO NOT GREASE.
Brett,
Just wondering. Since you see and know of, way more failures of the sealed bearings on CAT C-7s (like mine) than all of us put together, how do you compare that particular sealed bearing, with just about any other non-lubeable bearing on any accessory, on not only diesel engines but gas ones too? In other words, there's zillions of non-lubed bearings on zillions of accessories, i.e. water pumps, alternators, tensioners, idler pulleys, and more that have upwards and more of, 100K miles and are still going strong.
Our C-7 presently has over 70K on it and, at last check, when I pulled the radiator and CAC, that fan hub bearing was in flawless shape, and that was around 12-15K miles ago. That's not to say it's in perfect shape as we speak, I've not been in there to check it presently.
I know and realize that, there's a tremendous amount of strain and torque on that particular bearing due to its local in the engine drive train and, not only that but, the pretty fair amount of heat it's exposed to.
I was just wondering, if you could expand on your experience with the failure of both the lubed ones and the non-lubed ones. That is, what kind of mileage, on the average, would both see before a potential failure? I'm assuming the lubed one SHOULD last longer but, lubed things fail too.
Scott
