Aug-28-2016 03:08 PM
Aug-29-2016 08:33 AM
Aug-29-2016 04:15 AM
Aug-29-2016 03:26 AM
Kidoo wrote:
The Glass mount antenna looks like a good looking set up, but will it perform? It has no ground and energy workd through the window? I have doubt on that system.
Aug-29-2016 02:46 AM
Kidoo wrote:
Hi, I am looking for information about mounting a CB antenna on a class A. I do not plan to use this set up for very long, just for a trip with a bunch of others with CBs.
I read it needs a good ground to perform well. The problem is to ground the antenna on the fiberglass frame. I have an aluminum roof so a magnet is out of the question.
I saw a Firefly fiberglass antenna but it also need a ground.
Can I run a wire grounded to the frame from below the RV instead of screwing in the fiber? Really do not want holes in the fiber.
I also read it needs to stick out on top of the MH by half it's lenght otherwise it will not perform well, an that a 4 feet antenna is the minimum lenght.
I do have an old two part antenna with a magnet but I don't think I can fit it without the magnet.
Thanks, please share your experince.
Aug-28-2016 06:52 PM
Aug-28-2016 05:09 PM
Aug-28-2016 05:02 PM
Aug-28-2016 04:51 PM
Aug-28-2016 04:00 PM
Aug-28-2016 03:55 PM
Aug-28-2016 03:48 PM
Aug-28-2016 03:46 PM
