enblethen wrote:
Double throw circuit breakers are only used in specialized systems. They are not used in houses or MHs.
You are confusing them with wafer, thin, tandem breakers.
This should be what you have not necessarily a Square D.
Tandem circuit breaker.
Circuit breakers are the same as residential.
Correct!
CB's for home or RV are standard single pole...available at any hardware store. Even ones that are GFCI CBs
And some times the installers will wire the converter feed to a breaker used for another appliance...ain't right but have seen it done.
