bycrackey wrote:
enblethen wrote:
Double throw circuit breakers are only used in specialized systems. They are not used in houses or MHs.
You are confusing them with wafer, thin, tandem breakers.
This should be what you have not necessarily a Square D.
Tandem circuit breaker.
This style is common.
Tandem breaker
Circuit breakers are the same as residential.
maybe in yours but not my 08 bus.the breakers are shorter than house breaker,s and about a inch wide and are double throw per breaker most likely referred to as tandum.they do not look like my S+B house breakers such as the pictures u listed
Double Throw???
Those are used to transfer loads from one source to another source
Tandem is a double single pole CB (know as cheaters) that take up one panel space and feed two different circuits---each with own on/off/trip
