- George_BeggsExplorerWhen I changed my 1999 F53 it was so tight that after I got the belt started, I had to crank the starter to get it fully on.
- chucl66ExplorerOld f...... thanks. I have a breaker that be jusr right.
chuck - OldF__tExplorer
chucl66 wrote:
Thanks. What size is the tension nut? Will save my old body, from having to use trial and error method.
Thanks again
On mine it is not a nut. It is a square hole that a 1/2" drive wrench handle fits into. - chucl66ExplorerThanks to all!
Chuck - chucl66ExplorerThanks. What size is the tension nut? Will save my old body, from having to use trial and error method.
Thanks again - rgatijnet1Explorer IIIDon't know about the Ford but on my WH chassis, I used a ratchet strap to hold the breaker bar to keep tension off of the idler pulley. This allows me to use both hands to position the belt and then I can release the spring loaded idler pulley once everything is in place.
- jyExplorerI did my 99 F53 V10 from the bottom.Wasn,t too bad,the engine was cold.wouldn,t want to do it on a hot engine.
About Motorhome Group
38,707 PostsLatest Activity: Feb 18, 2025
