msg1951 Mine look like the letter P laying down on the long end if that makes sence. The leds are in the circle of the P and the flat part is stapled to the wood trim. I would believe a good pair of side cutters dykes come to mind would allow you to pull several of the staples and the rest may come up with the light strip. I lost count after 100,000,000 but there are plenty used. If you could find a stapler short enough to fit between the cieling and the trim you could lay the new ones out and re staple. I dont think it would be a big problem. Getting a stapler that you could fit may be a problem. They were small staples. Good luck Larry
