Jan-13-2016 07:48 AM
Jan-16-2016 08:20 PM
Jan-16-2016 12:28 PM
Jan-16-2016 10:30 AM
Jan-15-2016 04:42 PM
smkettner wrote:jerseyjim wrote:Trik-L-Start draws 5 milliamps and will drain a typical battery to 50% in 10,000 hours or 400 days.
I have a TRIK-L-START and it works fine...as long as you're plugged into shore power (like snowbirdng, for instance). Simply put, it "cannibalizes" the power from the 2 6V batteries into the 12V starter battery so it never runs down....and you can always start the motor, and in addition all the stuff powered by the 12V starter battery keeps going.
However....MY experience with the gadget is that if you leave everything intact when NOT being on shore power, (storage, for instance) ALL the batteries drop after a month or two. No coach power...no engine start power. Then the jumper cables come into play.
Just saying it is the other parasites.
Jan-15-2016 01:30 PM
Jan-15-2016 12:44 PM
Jan-15-2016 11:55 AM
dstock50 wrote:
Why not just connect the positive house battery to the positive engine battery through a fuse in case a battery goes bad so the house charger won't boil the other dry, or use a standard simple diode/HexfET battery isolator.
Jan-15-2016 11:04 AM
Jan-15-2016 10:40 AM
Jan-15-2016 01:55 AM
Jan-14-2016 03:53 AM
Jan-14-2016 01:19 AM
Jan-13-2016 07:22 PM
Jan-13-2016 06:56 PM
harley-dave wrote:
I added a trik-l-start to our class c and it works like a charm.
Dave
