wtmtnhiker wrote:
The coach has been sitting since last Oct 2017. My wife and I were going to head south last February but she got sick, she passed away in June.
I haven't decided whether to keep the motorhome or not but Thursday I took it out for an overnight just to see how it would be alone. The charging system is not working and the check engine light came on seemingly when the battery voltage got too low. When I turned off the lights and and AC the cel went out once the batteries recovered some on their own.
I have looked at the alternator and all connections seem fine. I tapped on it slightly to see if I could free up any potentially stuck brushes. Battery connections are good, clean and tight.
I wanted to try to figure out what I would need for a replacement alternator just in case but I do not see any tag or numbers on it anywhere. Any help or suggestions would be appreciated. Likely I'll need to take it to the garage.
2005 Holiday Rambler Ambassador 36PDD
You should be able to run the generator and for getting enough of a charge for driving it home.
Once there or even with where you're camped, the best thing is to remove the alternator, once verified bad and take it to NAPA or other for a match and also with possible having the originally pulley changed out.
