Sep-04-2012 10:19 AM
Aug-05-2013 02:54 AM
Aug-04-2013 03:45 PM
Aug-04-2013 03:37 PM
wolfe10 wrote:I've, done the on/off switch that Bret mentioned on a semi truck one time awhile back and it worked out really well! Sorry to hear about the accident and glad everyone is O.K.!
You would have to look at the wiring diagram for your coach to see where the disconnect is located in relation to the alternator feed, feed to ignition-controlled breakers, etc. Not sure there is a "one answer fits all".
If you have the least concern about it, remove any solenoid-controlled disconnect and install a simple marine ON-OFF switch. Most are rated for 360 amps continuous and are just a little over $20. Totally mechanical and designed for the harsh marine environment.
Aug-04-2013 02:19 PM
Thor sent me the recall instructions today. All they are doing is bypassing the Chassis Battery Disconnect so after the recall is done you will not be able to shut off the chassis battery using the switch. The recall just moves one wire on the BCC under the hood. The instructions are attached.
Aug-04-2013 09:56 AM
Aug-04-2013 06:40 AM
Aug-04-2013 06:36 AM
Aug-04-2013 06:10 AM
Aug-04-2013 06:07 AM
Lobstah wrote:yes, within the last week I think
Wasn't there a post recently about a recall on certain model coaches that use the BCC? Symptoms described in the recall sound similar to what you're describing.
Jim
Aug-04-2013 05:58 AM
Aug-04-2013 03:52 AM
Aug-03-2013 06:16 PM
Nov-10-2012 09:22 AM
K2kane wrote:
BluesLover,
I agree, eliminating this single point of failure is ideal and best. I too lost ALL POWER when mine failed - power brakes, steering, gauges, motor, everything! I was lucky to have been in the slow lane, in light traffic, and have a hard shoulder to move onto. This scenario would be devastating if this happens in heavy traffic, winding roads, steep mountain pass, etc.
Nov-10-2012 09:02 AM
Nov-09-2012 07:02 AM
