Driftwood1942's avatar
Jul 01, 2014
Chassis Wiring help needed
1995 Fleetwood Bounder 32' on Chev P30 chassis with 454 gas engine. Need electrical schematics for chassis, and diagrams for the in-dash fuse panel along with locations of emergency flasher and horn relays. GM says not available. Fleetwood says not available. Manual supplier wants $250 for the info. Please help.
  • I have a 1996 Fleetwood Flair, Fleetwood emailed me the RV wiring.
    I can email you that if you think it will help. As far as the P32 Chassis manual, it is a two book set and you can find them online used for 20 to 30 bucks.
    My books part number are GMT/96-P3-1 and -2 might want to search using 95.
    I hope this helps.
    Jeff D.
  • Welcome to RV.net!
    I use a Chilton's manual 28642. It covers Chev. P chassis. It has the basic wiring diagrams and many other chassis information.
    The flasher is located above the ignition switch above the steering column.
    I believe the horn relay is in the same area.
    Nice chatting with you!
