Effy wrote:
I haven't ever heard of anyone installing the Z brackets on the front bottom. I don't want to add doom and gloom but that seems a little risky. If you have popping I would identify the root cause of that and not modify the design to attempt to cover it up. Might be a recipe for failure. But that's me. You'll notice, each place there is a Z bracket there are 2 bolts to secure the connection. If you add it to the bottom you can't do that. Because it's not designed to go there. Not to mention it would add another point of flex which may erode any advantage you had of doing chf in the first place. Good luck.
I guess I just don't understand your concern. Mounting Z brackets on the front bottom would be exactly like they are mounted on the rear bottom. Using the existing link bolt and the extra hole in the sway bar. You can see the hole in the bottom left corner of the first picture. How is the front and rear different?
Google Ford TSB 04-11-02 and you'll see how Ford says to install the Z bracket on both ends of the link. Sorry, I'd post a link to the TSB but it's a PDF file and I don't know how to attach it here.
TSBMaybe this will work.
