windmill_bob
Oct 17, 2013Explorer
Chev 454 engine air cleaner intake assembly
The thermostatically controlled flap plate from exhaust manifold tube in the air intake horn has broken loose.
Likely no problem except slower warmup in cold weather. However, can too much heat from the exhaust manifold be a problem?
I had noticed that the carb air cleaner cover gasket has gotten hot enough to stick and pealed off some of the rubber gasket. Can't find replacement gasket seal.
Could have flap plate welded again in place or just cover port completely??
Your opinions would be appreciated.
Windmill Bob:@
Windmill Bob:@
